GTX 570 Driver Problem
I started up my computer for the first time today.Installed windows 7 64x, installed the motherboard drivers, then went to install the video card drivers for my GTX570 and this is what happened I get this error:
NVIDIA Display settings are not available - You are not currently using a display attached to an NVIDIA GPU
and in the device manager:
Windows has stopped this device because it has reported problems. (Code 43)
I also try to open the Nivda device manager but I get the same error
I have tried installing the latest drivers and the ones I got with the card.I rebooted windows and the same problem occurred.Anybody help me out with this.
3 answers Last reply
More about driver problem
  1. Post all your specs and make sure you have power from the PSU hooked up to the card and that your monitor cable is hooked to the card not the motherboard.
  2. Checked again power from the 950W PSU is hooked up to the card and monitor cable is connected to the graphics card.The fan on the card is also spinning.
  3. Sounds like a bad card.
Nvidia Device Manager Drivers Graphics
