Solved
Need Help-600-700$ Mini Itx Build
Hi i need help building a Mini Itx Build for 600-700$.
Approximate Purchase Date: e.g.: this week
Budget Range: 600-700 for the system and nothing else
System Usage from Most to Least Important: Gaming (Starcraft 2, any playing any other games on medium-high settings.)
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg
Parts Preferences: No Preference
Overclocking: Maybe
SLI or Crossfire:Maybe
Your Monitor Resolution: 1920x1080
Additional Comments: Needs to be quiet and cool and most importantly fast. Must have ssd.
3 answers Last reply Best Answer
More about need help mini build
  1. Best answer
    This is a touch over your budget but should be perfect for your usage. You won't be looking at ultra high settings in more demanding games like BF3 and Skyrim but you should get ultra high in most games.
    Intel Core i5-3450
    8GB Crucial Ballistix Sport 1600Mhz
    ASRock H77M-ITX
    HIS iSilence HD 7750 1GB
    Intel 330 Series 120GB
    SeaSonic M12II 520 Modular PSU (Overkill but a steal at $59.99)
    Bitfenix Prodigy
    Coolermaster Hyper 212 Evo
    Total - $724.92 on Newegg
    That would give ultra high settings for most games, more demanding ones would probably be more like medium-high and it should be extremely quiet.
    If you can't afford that I'd just swap the CPU for the i3-2120. It would still be fine for any game at the moment.
    If you don't need a modular PSU, the Antec EA-380D is a cheap alternative to that Seasonic too.
  2. Best answer selected by TheBerryBeast.
Build Monitors Systems
