Archived from groups: alt.cellular.cingular (More info?)
Would a poor battery Cause a loss of signal ? My battery will go from
a full charge to 1 bar of strength in less than 24 hours. Just
wondering if this causes a reception problem. Thanks.
[POSTED TO alt.cellular.cingular - REPLY ON USENET PLEASE]
In <g9i6g1paugtb65umcoo2n6e77ddesihv4c@4ax.com> on Wed, 17 Aug 2005 14:29:22
No, other way around: poor reception depletes the battery faster.
Best regards, HELP FOR CINGULAR GSM & SONY ERICSSON PHONES:
John Navas <http://navasgrp.home.att.net/#Cingular>
On Wed, 17 Aug 2005 14:29:22 GMT, For <kforaker@carolina.rr.com>
Yes, it's possible. Depending on the technology the phone uses if the
phone has to constantly look for signal its battery life will be less.
If it uses CDMA technology (Sprint PCS and Verizon for instance)
You've got it the wrong way around. The OP asked if a poor battery
causes poor signal reception, which is certainly not correct. Though,
poor signal reception can cause reduced battery life.
Being that this is a Cingualr newsgroup, it's safe t say that he's
probably using TDMA or GSM.
E-mail fudged to thwart spammers.
Transpose the c's and a's in my e-mail address to reply.
