Solved
Does corsair vengeance 1600mhz ram work with intel pentium g850?
does 1600mhz ram work with the intel pentium g850 processor?
8 answers Last reply Best Answer
More about does corsair vengeance 1600mhz work intel pentium g850
  1. Best answer
    yes, but you can only run at 1333MHz due to to the limitation of the G850's Memory controller.
  2. does it automatically goto 1333mhz or do i have to change something in the bios?
  3. most likely it will default. depends on the MB. what model is it?
  4. CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
  5. GIGABYTE GA-B75M-D3V LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
  6. Best answer selected by joshuuaa34.
    should default to 1333
  8. ok ty very much :D
Homebuilt Pentium RAM Processors Corsair Systems
