Hello, I'm building a custom PC and I am looking at the cooler "Cooler Master RR-T812-24PK-R1" and was wondering if it would fit the "asus Rampage IV Extreme X97 Motherboard" someone please help?
Welcome to Tom's Hardware Forums,
That cooler will mount on the socket 2011 motherboard - your concerns are going to be ram clearance and case width - is the case wide enough to handle that large of a cooler. I would suggest getting ram without large heatsinks (then clearance shouldn't be a problem) and installing the ram before installing the HSF
Hope it helps some
Ok,thank you for you help,I read there'll be enough room,also it's a full tower case and the case is cooling masters as well,and thanks again for the response
