Solved
Need new Power supply
I bought a Corsair CX500 for my build, and under a heavy load during benchmarking, the PSU overloaded.
Anybody know a good replacement, i'm going for a 600 watt and over PSU now. no more 500W for me :/
perferrably around 79.99
Specs:
FX-8320
radeon HD 7850
WD Velociraptor 500Gb
ASUS M5A97 R2.0
Lite-on DVD burner
CM Storm Enforcer
17 answers Last reply Best Answer
More about need power supply
  1. specs ?
  2. FX-8320
    radeon HD 7850
    ASUS M5A97 R2.0
    Lite-on DVD burner
    CM Storm Enforcer
  3. XFX Core series - 650 or 750 watt - your choice!
  4. Hi :)
    ANY decent make 500 will do...
    I would be more worried about WHY your previous one blew (and its NOT because its a 500)
    All the best Brett :)
  5. There's a Reason i RMa'd it for full refund, lol.
    Out of stock on Newegg :'(
    Hi :)
    WHAT reason...good make psus rarely fail unless the user screws up badly ?
    Trust me, its worth going somewhere else or waiting for stock, I have the 850W and I have never looked back. Good clean power in a tidy unit.
  9. How much are you willing to spend? I would go for a Seasonic X series if you want stable and reliable.
    huh
    i'd say 79.99 is my max.
  12. Tman450 said:
    huh
    Or 550w, depends what you end up doing in the future :)
    i would like to order through newegg, i have a gift card :/
  14. Best answer
    Yes .Its just great. Get it if you have the money. It has great reviews and golden award
  15. Best answer selected by Tman450.
Power Supplies Components Product
