GTX 560 TI FPS DROP. HELP
Recently i installed my GTX 560 TI and 650w PSU but.. on some games i get bad fps drop like on blackops it goes down to like 10fps every 5seconds or so, but when i had my HD5770 i could play it fine :S whats the problem!? its not all games but quite alot, older ones like wow and cod4 are fine.
GTX 560 TI
CIC 650W PSU
X6 PHENOM 1055T
ARCTIC FREEZER 13 CPU FAN
4GB DDR3 RAM
11 answers Last reply
More about drop help
  1. Hi
    Did you uninstall the old AMD drivers before installing the nvidia drivers?
  2. No, not before but i have uninstalled them yesterday
  3. Turns out amd catalyst was still there, let me try now and see how games run
  4. I'd reinstall windows. When dealing with AMD drivers, it's impossible to completely remove them from your computer and their remnants poison Nvidia graphics performance. I don't know whether they do this on purpose or not, but that's the case, and personally, I haven't found any way at all to fix it without reinstalling windows.
  5. Rustyy117 said:
    Hi
    Ahh okay, thanks. i guess its gonna be a 10hour back up proccess for me :L need to factory restore tbh
    Ok, let us know how you get on.
    Okay, im backing up all my files now, then im going to factory restore, then tell you if its the same or not
  9. THANK YOU EVERYONE! IT WORKED.
  10. Sorry ya went thru all that.....I have never had an issue getting old drivers out tho.
    Option 1.
    1. Download latest nVidia drivers
    2. Uninstall AMD drivers.
    3. Use registry cleaner to remove all things AMD
    4. Reboot
    5. Shut Down machine.
    6. Remove old card / Install new card
    7. Boot to Windows
    8. "Just say No" if Windoze wants to install anything
    9. Install new drivers.
    Option 2.
    3. Run DriverSweeper
    4. Reboot
    7. Boot to Windows
  11. Glad you solved it!
Graphics Cards Gtx Games FPS Graphics
