Will my power supply be enough?
Last response: in Components
Hello everyone,
I have a 550w power supply and my current system is:
-ASUS P8H61-M LE
-Intel Core i5 2400
-Asus ENGTX 560 TI
-8gb Ram
-A mediocre optical disc drive
-Western Digital WD10EZRX 1TB 7200 rpm SATA 6 HDD
550w power supply is enough for my current system but I want to replace my motherboard with an ASUS Sabertooth z77 motherboard. My question is when I change my motherboard to sabertooth will my power supply be enough to run the system?
Thank you in advance.
More about : power supply
milkshakez7z said:
What brand is the PSU?
The power supply was included with my gigabyte chassis so it should be gigabyte too.
willyroc said:
Yes. A decent 550W can even run SLI 660 Tis.
Actually I don't intend to use multiple gpu atm. I just want to upgrade my motherboard to sabertooth and since sabertooth is much better than my current mobo I am worried that my psu won't be enough.
