Solved
Upgraded computer parts, compatibility issues???
  • Homebuilt
  • Computer
  • Windows Vista
  • Systems
Last response: in Systems
July 23, 2012 11:13:36 AM
Okay, we'll I recently upgraded some of my computer parts which would be the mother board, CPU, ram, and gpu.I decided to keep my hard drives since I saw no reason to buy new ones, but after I had put everything together I could not run vista in normal mode so I had to go into safe mode to try to install all the drivers for my mobo and gpu. However whenever I would try to install the drivers for the mobo a box would pop up saying "open handle failure" or something very similar to that. I couldn't even get the drivers for the gpu to install! So I figured that vista was just having a tantrum from all this new hard ware ,so I downloaded Linux sabayon 9 off another computer and put it on a cd to see if I could at least get my computer to boot up from a cd (since I lost my original vista cd) but I found that My computer would read Linux on the cd but when ever I would click "start sabayon" it would freeze on a screen that was sometimes different colors but it was always a bunch of vertical lines going across my screen and I would have to restart the computer. So I caved in and bought windows 7, and switched out my main hard drive with the hard drive that was meant for storage(but I never really used it) And I tried to install windows 7 onto that hdd, but even with that setup windows 7 would just freeze at the "starting windows" page or end up freezing at a screen with those same damned vertical lines?? Anyone have any ideas what this problem could be??
Old computer specs
Mobo - Evga 750i sli
CPU- q6600 @2.4mhz
Ram - 4 gbs corsair memory
Gpu - (2) Xfx 9800gtx
Psu - ultra 1000watt
Western digital velociraptor(has vista on it)
My storage drive was 640 which I never really used but that's what I tried installing windows 7 to after I took out the velociraptor
Upgraded to:
CPU - AMD fx 8150
Mobo - gigabyte 990fxa ud3
Ram - 16 gb corsair vengeance 1600mhz
Gpu - xfx hd radeon 7750
More about : upgraded computer parts compatibility issues
Best solution
a b B Homebuilt system
July 23, 2012 4:34:00 PM
If you haven't, you need to format the drive. Going from Intel to amd makes it a necessity; too many different video and board drivers that need to be cleaned up.
