Help on this build
Intel Core i7 2600 Processor LGA1155 3.4GHz CPU
Antec KUHLER 2011 Mounting Kit, For H2O 620/920, Support Intel LGA 2011
Intel DH77KC Media Series ATX M/B, LGA1155,H77,DP,HDMI,DVI,4x DDR3,PCIe x16,
Corsair CMX8GX3M4A1600C9 8GB (4x XMS3 2GB) PC-12800 (1600MHz) XMS KIT
Hitachi 1TB Ultrastar SATA 7200RPM 32M
Corsair 30GB Accelerator Series SSD Cache Drive: An easy, affordable way to boost system performance
Power Colour AX7870-2GBD5-2DHV2 HD7870,10000Mhz,2G,DDR5,PCIE3.0,DVI,HDMI,2XminiDISPLAY
AOC e2250Swd 21.5" Full HD LED Monitor - Full HD1920 x1080p, 20,000,000:1 Contrast (DCR), 5ms, DVI+
BLink LW07-A2 Wireless PCI-E 300Mbps Adapter
Antec 520W High Current Gamer Modular Power Supply, 80 PLUS Bronze
This is $1508 in total, I was wondering if anyone could give me some tips to improve this set up.
I'm looking for a system that runs good with games without being a gaming rig so it can still run well with video editing and graphic design.
2 answers Last reply
More about help build
  1. Downgrade to an i5 3570K, which would still do decent unless you edit for work. Id upgrade that SSD to 64GB as 30GB never suits my needs. 8-16GBs of RAM will do good, depending on how many programs youll have open at the same time. Upgrade GPU to 7970. And I say get a 600W PSU, for the future :)
  2. Since your using a 77 series motherboard i would recommend going with an ivy bridge processor
    And using a z77 motherboard to give you more controle over your processor and and the possibility of using a second graphics card in sli/crossfire
    MSI Z77MA-G45
    Other than that looks good
New Build Systems
