I am looking to build a new computer, my main focus is gaming with some graphic work on the side. My goal for the computer is for it to run anything out now and for a while hopefully and be open for easy upgrade in the future. My budget is $2000.00, so when I saw the June 2012 System Builder Marathon $2000.00 pc I figured I would just build that.
http://www.tomshardware.com/reviews/core-i7-3770k-overclock-geforce-gtx-680,3212.html
My first change to that build was to switch the graphics card out for a EVGA 680, had good customer experience with them before when helping a friend sort out a bad card. I am planning down the road to be able to stick a second one in and sli them.
EVGA SuperClocked GeForce GTX 680 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?item=N82E16814130769
The next was to switch out the memory for something bigger, I wanted to start the computer off with 16gb if I could and from a recommendation from another forum topic I started I came to these.
CORSAIR Vengeance LP 16GB (2 x 8GB) 240-Pin DDR3
http://www.newegg.com/Product/Product.aspx?item=N82E16820233280
So now I have a build that I know will work well, perform as I want. My only worry is that reading through the system build it talks about not being able to fit a second video card because of the size restraints of the case and motherboard. So what I think needs to happen on this build is a revaluation of the case and maybe the motherboard. If a new case would solve the problem without needing to change the motherboard that would be awesome. The following two links are two cases I have been looking at as alternatives for the Antec 900.
I kept seeing the name of this case mentioned in comments and forum posts, seems to get good reviews. Not sold on a front plate but looks good and has a nice I/O placement.
NZXT Phantom PHAN-001WT White Steel
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
I like the accessibility of this case, the hot swap sata on top and again convenient I/O. Cant stress an I/O on top enough, my current 8 year old pc has them as low as possible, pain to plug usb in when I cant see the plug.
Antec DF-85 Black Steel / Plastic ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129087
My problem basically boils down to space, if I need more than the antec 900 provides or how do you even know before you have parts in hand that these pieces will fit? I see tons of details on connection type and speed but never the measurements like the height of ram. Any response is greatly appreciated, I know most of these questions are probably newbie problems but as I stated in an earlier post I know just enough to over think what I am trying to do and screw it up.
EDIT: Just wanted to add is the third picture down on this page that worries me, dosn't look like enough room for a second gpu in there.
http://www.tomshardware.com/reviews/core-i7-3770k-overclock-geforce-gtx-680,3212-6.html
Also added headers to my links.
