2 Sound cards to 1 headset?
Hello there!
So, I have been wondering a bit about something. I have 2 sound cards in my PC, the onboard one and then a Creative X-Fi Titanium Fatal1ty Pro one.
I would like to ask, is it possible to use both soundcards and have them send out to the same headset?
What I was thinking about doing is set Mumble to use the onboard soundcard, and the Creative for everything else, then have them come out together through my headset. The reason why I would like to do this is because with Dxtory this would allow me to record 3 sound channels when recording gameplay (1 game track, 1 mic track and 1 mumble track, so if I want to eg remove all mumble sounds I can easily do that without anything happens to the other 2 tracks).
I have heard something about being able to use a mixer or something, but is that true? If so, what should I be looking for?
Also, before getting comments about "Use VAC" - that's what I'm doing atm, but I would like to know if there is a more reliable way as VAC isn't always working properly for me :)
3 answers Last reply
More about sound cards headset
  1. You would need an external mixer to do this but you might be able to loop a stereo putput of 1 card to the aux in of another if the creative will let you mix the input with the other sounds.
  2. Smart thinking popatim.
    Thank you, will look into trying that :)
    However, I first need an extra cable to try and do it, and while I'm waiting I would like to know this; If it doesn't work and I would need an external mixer as you said, what would you suggest me taking a look at?
    Edit: Got the cable I needed, and everything seems to be working fine! Thanks for your help =)
Sound Cards Gaming Headsets Creative Components
