Solved
Best power supply for 90$?
My specs are,
Over volted 1045 T running at 3.8 ghz with a coolermaster Hyper 212 evo.
Over volted 7850
2xCorsair XMS3
Gigabyte 990fxa ud3
1x hardrive and DVD R/W.
I want something that can handle liquid cooling, SLI/xfire( if possible for the price) and what not. Modular is preferred.
I've been recommended the Rosewill Capstone 450m by a lot of people, but I want to expand my options a bit. According to your opinion, whats the best quality PSU I can get for about 80-90$?
17 answers Last reply Best Answer
More about best power supply
  1. The Capstone is a good unit but would be very taxed in SLI/X-fire (if it could even do it since most graphics cards recommend 750W for SLI/X-fire).
    This one would work quite well I would think except it is not modular but it would be my choice for your budget/needs CORSAIR CX Series CX750
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139040
  2. yea thats a good one, theres rebates on the 650 also I beleive.
  3. If I'm not going SLI, and if I buy a high end card like a 680 or a 7970 instead of going dual 7850, would this be a good choice?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
    or
    if I'm not going modular, http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
  4. I'd go with the SeaSonic G Series SSR-550RM without reservation
    I will second that ;)
  6. Oh ok, would be enough to handle heavily OC'd CPUs and (single)GPUs? For example an 8350 at 5.0ghz with an overvolted 7970?
  7. Best answer
    You'll probably be looking at less than 350W under full load, it can handle that no problems, you could even add a full water loop, multiple fans, HHD's etc... and you'll still be fine
  8. Ok thanks, one last question though,
    Between the m12ii and SSR 550, which on e is better?
  9. The SSR is a more efficient PSU, 80+ Gold vs. M12II 80+ Bronze certification
    hmm.... If thats the only difference then It would make more sense getting a m12II right?
    No it would not make more sense there is 30W difference if you want a cheaper power supply just say that :lol:
  12. Lol they're both 89.99 ?
    No one is 79.99 the other is 89.99 :D
    Oh my bad lol I was comparing the 620W version to the 550W version.
    I'll just go with the G 550W then. I've read reviews on jonyguru and hardware secrets both gave the G550 a better score. Thanks for your input :D
    No problem.Your welcome! :)
  16. Best answer selected by shuman95.
Power Supplies Cooler Master Components Product
