I5 3570k GTX 670 New build, Compatible Parts?
Approximate Purchase Date: Couple of Months (~October)
Budget Range: 2000$
System Usage from Most to Least Important: Gaming, Youtube, School Work, Surfing.
Are you buying a monitor:No
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg.ca
Overclocking: Yes
SLI or Crossfire: No
Here are the parts:
CPU-http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116504 (i5 3570k Ivy Bridge)
Case-http://www.newegg.ca/Product/Product.aspx?Item=N82E16811139006(Corsair 650D)
GPU-http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125423 (Gigabyte 2gb GTX 670)
Memory-http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145345 (Corsair 2x4gb Vengeance Ram x2)
Heat Sink CPU Fan-http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103099 (CM 212 Evo)
Motherboard-http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131818(Asus P8Z77-Deluxe)
HDD-http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136533(WD 1TB Caviar Black)
SSD-http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233191(Corsair Force Series GT 120gb)
PSU-http://www.newegg.ca/Product/Product.aspx?Item=N82E16817121067(Kingwin LZ-850 80+Brz)
Dvd drive-http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204(Asus DRW Sata DVD Drive)
Thermal Grease-http://www.newegg.ca/Product/Product.aspx?Item=N82E16835100007 (Artic Silver Grease)
-------TOTAL$--------
$1,952.36
So will all this fit in the case and will the PSU Be able to power them all...(Ie the right cables)
5 answers Last reply
More about 3570k build compatible parts
  1. i only answer your question.
    is it fit? - Yes
    Is it enough power? - Yes..
    But, is it enough power when you do SLI on your GTX670 in future plus overclocking! you should take 700w or 750w.
    Thermal greese should come along with you CPU (i5-3570K)
    P/S: i still feel there is no need for you to go to GTX670.. GTX570 will be more than enough but depend on your monitor resolution..
    GTX670 will beneficial for high end game + bigger resolution /+ multiple monitor..
    i also wont take Deluxe MOBO.. why not you go to Asus P8Z77 V-Pro mobo? or Sabertooth Z77?
  2. It will all fit just fine. You have an ATX motherboard going into an ATX case, all good.
    You have too much power 850W is overkill for even a dual card rig. Considering you wont go above a single, 650W should be more than you will ever need. Also, Kingwin arent a reliable brand, its quality is unknown. Get a 650W from either Corsair, Seasonic, XFX or Silverstone. Make sure its 80+ Bronze or better and preferably modular.
    You dont need the Arctic Silver, the 212 EVO comes with some rebranded MX-5 thermal paste. The CPU does come with its own heat-sink with pre-applied thermal paste, but dont use that.
    You dont need such an expensive motherboard, considering your only going with one GPU, you can easily get a cheap micro-ATX motherboard that will serve you just as well.
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157294
  3. I THINK THE MOBO IS TOO BASIC... C'MON, GO FOR ASUS P8Z77-V OR P8Z77-V-LX..
  4. i changed the mobo and psu to
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131819(asus p8z77 pro)
    i prefer atx boards so i can upgrade in the future, resolution will probably be 1920x1080 and psu ive selected is
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139012(corsair hx750)
    what do you think?
  5. The mobo of Pro should come along with WIFI adapter and router (wifi go), unlock and a decent choice..
    well, the PSU is more than enough.. haha,, it is a GOLD rated.. it is one of the high end of the Corsairs's PSU.
    the power is good enough.. it is up to you if you want to buy a gold series of psu, but fyi, bronze series actually not a bad choice too.. its up to you..
    if you want to use 1920 x 1080, then i recommend u to go to Asus HD7850 DCU II or HD7870 DCU II or Asus GTX570 :) ... these gpu will provide you the best (max) up to 1200, so 1080 not a problem at all and will serve you as your wish SIR!
    There is no need to go to GTX670 at all.. unless you use a very big resolution and multiple resolution.
New Build Systems
