Tom's Hardware > Forum > Windows XP > Configuration & Customize > Problem with invisible IE window stealing focus
Forum Windows XP : Configuration & Customize - Problem with invisible IE window stealing focus
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hello.
I have a very,very annoying problem with my XP SP2.
There is an invisible IE window that steals the focus from any window
that is active(mail client,notepad..etc).
This is an example of what is happening:
I have only 1 window running and on taskbar-Notepad and start writing
something and suddenly
the window loses focus and I have to click in it again to make it
active.The funny thing is that there are no other windows that could
take the focus,so I press alt+tab after the moment in which notepad
loses focus and Windows shows that there are 2 windows:notepad and
IE,but if i try to switch to the IE window nothing happens(as if the
ie window is invisible).After this I kill the iexplore.exe process but
it happens again in a few minutes and iexplore.exe is active again.
The machine is fully patched XP SP2 with Norton AV 2005 and MS
Antispyware with the latest definitions.
I have searched a lot on this topic,tried TweakUI(prevent from
stealing focus option) but still no results.
Any help is GREATLY appreciated since this is very annoying problem
while writing and email,documents,etc.
Regards,
DamjanD.
Sponsored Links
Has been a popular post as of late. Without knowing the common glue
attached, here are some suggestions and checkpoints to consider:
TweakUI/General/Focus
http://www.microsoft.com/windowsxp [...] ertoys.asp
Prevent Programs from Stealing Focus - Undo (Line 66)
http://www.kellys-korner-xp.com/xp_tweaks.htm
When a window that does not have focus is updated by its program, the
default setting prevents it from becoming the foremost (top) window,
instead, it flashes in the taskbar.
HeldUp is the easiest way to stop windows from disappearing behind other
programs. http://www.johnmacintyre.ca/HeldUp.asp
Programs May Start, Quit, Lose, and Gain Focus Randomly
http://support.microsoft.com/defau [...] duct=winxp
Customize Auto Hide Taskbar Settings (Line 190) Right hand side
In memory of our dear friend, MVP Alex Nichol: http://www.dts-l.org/
All the Best,
Kelly (MS-MVP)
Troubleshooting Windows XP
"Dame" <damjand@gmail.com> wrote in message
news:53688a6e.0504140438.2d7b2472@posting.google.com...
> Hello.
> Regards,
> DamjanD.
Reply to kelly
There are 1391 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
