Closed
Do i need a sound card added
Last response: in Components
i would stick with the integrated one if you got a cheap pair of speakers or headphones. Unless you are an audiophile then I would go for a good card. Some people will swear by the card they can hear more dynamic ranges a card will give you. But with what your doing you will be fine with onboard sound.
ok :D  thank's for your reply
Related ressources
samuelspark said:
If you're going to buy one, go for the ASUS Xonar DG because it's better than most sound cards in it's range, even ones that more expensive. I mean, unless you use a nice set of headphones, and are a heavy music listener, you should be ok with integrated.
ok then :)  my friend told me to try listen from integrated sound card. I think that will be ok for me
