GRAPHIC CARD HELP
hi i have a nvidia geforce gtx 460 Graphics card but when i play games like call of duty on i get line going up the screen when its on a video part of the game i had it sorted out and the line went but i had to do a restore for my computer and it come back i change something in the nvidia control panel but dont know what i changed help please
8 answers Last reply
More about graphic card help
  1. Hi
    Have you tried forcing Vertical Sync via the nvidia control panel? Your problem could be screen tearing.
  2. Rustyy117 said:
    Hi
    HOW DO I TURN IT ON THANKS
  3. Go into the nvidia control panel, make sure its in advanced view, click on Manage 3D settings > Select global settings > Scroll to vertical sync > Force on.
  4. THANK YOU MATE
  5. IS THERE ANYTHING ELS I NEED TO CHANGE OF JUST THAT
  6. Stop with the caps! :non:
    Well if its solved the problem then no.
  8. all done now thanks for your help
Nvidia Graphics Cards Games Graphics
