Need Help! Lights Turn on all fans run but no display
  • New Build
  • Light
  • RAM
  • Systems
  • Product
  • Displays
Last response: in Systems
July 25, 2012 3:27:54 AM
I really need help after putting together my build i booted it up and all lights fans are working but there is no display. I have already tried everything posted here http://www.tomshardware.com/forum/261145-31-perform-ste...
As well as trying my ram and gpu on another unit both are working fine yet still no video. Could it possibly be my mobo is DoA should i issue an RMA
Specs
-Mb Biostar Th61 Itx H61 1155 R
- Sapphire HD6850
- Corsair 600W
- I3-2100
-Gskill 4Gx2
-500Gb Sata Wd5000
Edit: I also just realized i'm using 1600 mhz ram on a 1333/1006 MHz ram compatible board i heard that it would down clock the ram to 1333 MHz or is this why i'm getting no display
More about : lights turn fans run display
July 25, 2012 4:08:33 AM
bump
July 25, 2012 4:29:28 AM
Are you sure the PCIe 6-pin connectors are properly connected to the graphics card?
Also, tell me the PSU specs.
July 25, 2012 4:34:41 AM
Yes the 6 pin is correctly connected. I believe that my Psu is the problem. The LED on my board does not light up at all. My Psu is 600W corsair. I have also notices in the 24 pin connector 1 pin is empty. Any suggestion or ways i can check if my psu is at fault.
Also this may be wierd but my cpu fan does not fully spin unless my Gpu is connected.
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
July 25, 2012 4:45:54 AM
Are you sure your monitor is connected to the graphics card, not the mobo?
July 25, 2012 4:48:24 AM
Yes i have tried both
