1920 x 1080 or 1600 x 900 resolution monitor for new build?
Last response: in Systems
Total: 10 votes (2 blank votes)
  • 1920 x 1080
  • 88 %
  • 1600 x 900
  • 13 %
Related ressources
raytseng said:
a monitor is not going to go obsolete.
my advice would be to save up and then get the monitor you want, since you won't need to replace this for a long time
+1.
I'v been using the same 1920x1080 monitor for at least 3yrs. Get a good one and you wont have to buy another.
haha, great replies guys...anyways, i will recommend my friend for a 1920 x 1080...although imo, 1600 x 900 is not thatbig of a difference...
although, me myself, am using a GTX 560 Ti with a 1600 x 900 monitor..haha
been using my monitor for 2 yrs...
i got a 7 year old monitor(that works) that's making my 7850 go to waste till i replace it (max resolution is 1024x768 and can technically go 1280x7xx but is a bit glitchy) other than that, because of the forced low resolution, jokingly high fps count in games.
yep..you most probably have to downgrade to an Ati 4850 to fit wi....
nah, just kidding..hahaha :pt1cable:
heck, i could probably use the intel HD 2000 in the i3 chip and still get respectable framerate haha.
Ask the community
