Approximate Purchase Date: I would like it to be this week but any time is okay too.
Budget Range: I would like to keep it at $800 dollars but the cheaper the better
System Usage from Most to Least Important: Playing Minecraft, editing COD videos, and surfing the web.
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg.com, amazon.com
Parts Preferences: I want to go the intel route.
Overclocking: No, but will be upgrading to the i5 - 2500k once i have the money
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080, I'm using a 24" Haier HDTV
Additional Comments: I don't get what SLI or Crossfire is so can someone explain that to me? and I want to have a pretty quiet PC as long as the sound isn't to overboard.
Parts:
CPU: Intel i5 - 2400 Sandy Bridge 3.1 Ghz (3.4 ghz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000
Price: $189.99
Motherboard: ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Price: $119.99
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory
Price: $57.99
Case: Antec Three Hundred Two Black Steel ATX Mid Tower Computer Case with Upgraded 2 x USB 3.0
Price: $69.99
GPU: SAPPHIRE Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
Price: $169.99
Hard Drive: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Price: $109.99
Optical Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
Price: $19.99
Heatsink: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
Price: $19.99
TOTAL: $757.92
I didn't include a PSU because I didn't know what I needed to power this build, so feel free to give me any suggestions on a psu. It's okay if i go over the $800 dollar limit too.
