Build a pc and it starts for 2 sec and keep restarting HELP
Hi
I just build a computer and it starts and goes off all the time.
When i remove the memory it starts. i bought a new memory and it does the same thing
Antec Kuhler H2O 620 CPU-Kylare - Socket 775 / 1155 / 1156 / 1366 / AM3
ASUS GeForce G210 1GB SILENT (EN210 SILENT/DI/1GD3/V2(LP)) - PCI-E / DVI / VGA / HDMI
ASUS P8H61 B3 - ATX / Intel H61 / DDR3 / PCI-E / SATA 2.0 / USB 3.0
Corsair Power Supply (PSU) 430W CX V2
"old one" Corsair ValueSelect 4 GB DDR3 PC3-10666 1333MHz (CMV4GX3M2A1333C9) (2x2GB)
"new one" G.Skill F3-10666CL9D-8GBRL - DDR3 1333 Mhz - 2 x 4GB
Fractal Design Define R3 - Svart (Ej PSU / USB 3.0)
Intel Core i5-3570K - 4 trådar / 3,4GHz (3,8GHz Turbo) / 6MB / Socket 1155 (Boxed) (Upplåst) (77w)
Samsung DVD±RW Samsung 22X SATA Bulk Svart
Western Digital Intern Hårddisk Caviar Green 500GB SATA II (32MB Cache / SATA II)
2 answers Last reply
More about build starts restarting help
  1. "I just build a computer and it starts and goes off all the time. "
    Please be more specific. What do you mean by it starts? Does it POST, does it load windows or what?
    When you remove the memory you say it starts, I'm assuming here you mean it POSTs OK.
    Have you checked that the memory is compatible with the motherboard? The manual should list compatible RAM. Have you tried with just single sticks of RAM?
    Could be a faulty MOBO if none of the RAM is working.
  2. Yea, be as specific as you can. And use the best english you can so we KNOW what your saying.
Homebuilt Systems
