I'm trying to install my Xonar DG sound card into my ASrock Z68 Extreme3 Gen3 Motherboard, but it doesn't appear to fit. It seems like the bracket that you screw onto the chassis is too short, and therefore won't allow the card to fully slide into the PCI slot.
Any ideas on how to get it in there? Are these parts even compatible?
Edit: I'm using a HAF 912 for a case
