So I'm building a PC and everything was fine until I realized the fans were working, the motherboard powered on just fine, everything worked BUT the hard drive, and 2 optic drives I have connected. After messing with it a bit, I found out that the 4-pin molex's were fine, everything was fine except the SATA ones, I've tried using a converter (Molex to SATA) and it did not work.
Here is as much detail as I can put:
The power supply is a 650W Raidmax
I have a GIGABYTE motherboard, 2 optic drives, Nvidia GT640, AMD Sempron 145 and one hard drive onto it.
I've already tried using molex to SATA converters; it failed.
If I used the converter, it would work on other types of connection (3 pin, 4 pin) but SATA for some reason.
It is not a modular PSU.
The red voltage switch on the back is set to 230v instead of 115v.
The fans and motherboard worked .
I used a different power source and all SATA devices are working properly.
I'm not sure if its the SATA cables, Power supply, or how I set it up.
I'm not using any kind of LED light in it.
I kinda need help right now.
