Hello,
I've been using tomshardware for reference in my builds for a while but i'm upgrading and have received some conflicting info.
I currently have a Phenom II 955 paired with a Sapphire Radeon 6570 HD on an old case with a Jawan 600W PSU. Yes, I Know.
Well, i am short on cash and live in Colombia, so newegg is out of the question, and have about 300 USD to invest. I planned to buy a thermaltake v4 with a 500 W thermaltake PSU, with a Sapphire Radeon 6870 HD, and keep the same mobo and processor. That't hits my limit just right.
However, the vendor told me that I must use a 600W or 650W PSU (Though sapphire says that only 500W are needed). I will just believe the manufacturer for this one.
On the other hand he told me he doesn't think the case will be enough, something about 6870's not fitting or overheating or running way too hot in a thermaltake v4.
Approximate Purchase Date: two weeks from now
Budget Range: 300 USD
System Usage from Most to Least Important:gaming/entertainment
Overclocking: Maybe
SLI or Crossfire: Maybe/No
Your Monitor Resolution:1400*900
So here's the question: Will the 6870 run hot in a v4? is the airflow and headspace sufficient? Should i spend the extra buck and get something like this:
Azza Vulcan
http://www.amazon.com/Linkworld-LC3191-04-Silver-VULCAN-Chassis/dp/B008LA7JP0
Azza Spartan
http://www.amazon.com/Azza-Tower-Computer-Spartan-102E/dp/B004NSULRC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1343254254&sr=1-1&keywords=azza+spartan
If i do, however, i have to buy them with the included 600w PSU brand "omega" which i have never used.
Any piece of advice would be greatly appreciated.
Thanks in advance.
Overclocking: Maybe
Azza Vulcan
Azza Spartan
Thanks in advance.
