Closed Solved
Need help with Power Supply
Im fairly new when it comes down to upgrading Hardware of a computer. I currently own an ASUS tower. Link to my exact tower is here: http://www.futureshop.ca/en-CA/product/asus-asus-essentio-3rd-gen-intel-core-i7-3770-windows-8-desktop-computer-cm6870-ca001s-cm6870-ca001s/10223515.aspx?path=6513522f7abf8a03ac3fdb6b8e464c01en02
I want to add a better graphic card on it. I don't know which exactly, but I'm spending upto $250 on graphic card. From my knowledge, it appears my power supply only provides 300W and to be able to upgrade my graphic card I would need a better power supply. So if you guys can help my choose a power supply, please let me know the exact PSU I would need and that would fit well in my tower. I would appreciate any help.
Thank you.
8 answers Last reply Best Answer
More about need power supply
  1. Best answer
  2. Seeing as your not overwhelmed by links here's what I'll suggest.
    The 7870 for this price range is the best and should overclock quite well. I'd recommend staying away for the XFX series because it seems they have coil whine as a common problem (same with a few other brands such as powercolor). These are three of the better ones you have to decide how much you want to spend.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127681
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161423
    Personally if it was me I'd get the cheapest one because I'd overclock it past the factory overclock of the other two. This site also rated it's cooler to be the best on one model above it. http://www.tomshardware.com/reviews/radeon-hd-7950-review-benchmark,3207.html
    http://www.tomshardware.com/reviews/radeon-hd-7950-review-benchmark,3207-14.html
    As for a power supply I'll list you two options, the cheapest (but not bad) which won't be modular and a second option a bit more costly that is modular.
    non modular- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
    modular- http://www.newegg.com/Product/Product.aspx?Item=N82E16817341050
    Hope this makes your decision a bit easier. If you are in Canada you can look on newegg.ca and have most of the same parts although normally the shipping costs vary a bit.
  3. Well if what Anrewcarr says is true about the coil whine ( I have owned XFX Cards and they never had the whine noise but then again they didn't draw much power) then go for this:
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127662
  4. Agree wholeheartedly with that recommendation. Although the HIS cards still have a nice cooler. Seeing as the small price difference between the base MSI model and the top model I'd spend the bit extra on it.
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127681
    Or still this one that is quiet and a great cooler for overclocking (also a bit cheaper in the end).
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814161404
  5. socialfox said:
    Alrightey, how about this video card?
    First of all thank you very much. I appreciate that you took time to realize that I'm from Canada. My best option is NCIX.ca, bestbuy.ca and futureshop.ca . I live in Vancouver,BC (canada). I don't think I've heard of PC canada here anywhere.
  6. thanks all
    Thank you so much. I appreciate your help and thank you for taking a time out to solve my problem. Sometimes its hard to find stuff like this in Canada. But I'll look what you have mentioned in one of the canadian stores I usually go to.
    Well there is a NCIX store at this location:
    1711 West Broadway
    Vancouver, BC
    V6J 1Y2
Power Supplies Graphics Cards Components Product
