HAF 912 Power button header help
Last response: in Systems
Your Motherboard manual should have a part where it depictures how its connected (what pin goes with what connector)
The connectors from the case are marked with a very small name, when you find the manual, plug them accordingly and carefully one by one, and your front panel should be working just fine. If you dont find the manual, it should be in their website as well.
Hope it helps
Ask the community
