Aerocool x predator need help!
Hi tomshardware i have question i want to buy Aerocool x predator x1 case black evil and i wonder if in window of case is comes with leds?Because i see pictures in google and all of them is in leds?wonder because i want to save money!
3 answers Last reply
More about aerocool predator help
  1. I have the aerocool xpredator x1 white, I see no window.. what do you mean by the window?
    is this the case you mean XPredator X1? It's a White edition, but the composition of the case is just the same in all editions, the only difference is the color of case and the color of fans that comes with the case..
    If by all random chance what you meant was the Aerocool XPredator not the X1 version, which has a window..
    Finally the answer to your question.. If it is the XPredator or XPredator X1,
    both case have 1 front panel 120mm led fan (color depends on edition) and 1 rear fan 120mm (no led)..
    For more info read information regarding the case from Aerocool Website.
    Here are the links to their site:
    XPredator Evil Black: http://www.aerocool.com.tw/index.php/products/chassis/28-pgsb/110-xpredator-evil-black
    XPredator X1 Evil Black: http://www.aerocool.com.tw/index.php/products/chassis/28-pgsb/209-xpredator-x1-evil-black-edition
    If you want an awesome case, try the Antec Nine Hundred Two v3. Or an NZXT case.
    emm i means aerocool x predator x1 evil black!with window
  3. there is no xpredator x1 evil black with window.. it must be modded!
    the only thing in the side panel are two 120/140mm mesh-like-style holes.. see picture on the link! it is from aerocool website, so unless you're buying a brand new aerocool xpredator x1 evil black case, there is no window!
    if you're buying a modded case, ask the vendor what it comes with..
Power Supplies Cases Aerocool Predator Components
