Hello,
I built an HTPC and decided to test and install everything on my main computer's monitor before moving it to the home theater room. I unplugged my current computer's power cord and plugged in the HTPC. Realizing I forgot to copy some drivers, I plug my main computer back in. But when I pressed the power button, I heard a loud pop and the lights on my motherboard turned off. My computer was dead. I believe this was probably a blown capacitor the power supply since all the ones on my motherboard (ASUS Maximus IV Extreme-Z) looked fine. So now I have no choice but to swap the PSU out with a new one. My question is, if I buy the same unit (Thermaltake 1500W), can I just go ahead and unplug the cables from the dead PSU and plug them into the new one since this is a fully modular unit. Or would I have to use the cables that come with the new unit.
The reason I would like to know is because I would have to remove almost everything from the case to do this since my cables are routed in so many different places and all my components are water cooled.
Any help is greatly appreciated.
Thanks.
Thanks.
