9600GT low power - replacement?
June 3, 2012 8:23:42 PM
I have an old Dell desktop with the following specs:
System Model: Dell Inspiron 530
Processor: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz (2 CPUs), ~2.5GHz
Memory: 4096MB RAM
Graphics Card: NVIDIA GeForce 9600 GT
I know I bought the 9600 GT because it was low power, as I'm sure the Dell does not have a great PSU. Is there any replacement for this graphics card that would preform any better?
June 9, 2012 7:34:54 AM
Vettedude said:
The Inspiron 530 has a 300w PSU, and Dell uses pretty high quality units for pre-built.
This would be a decent upgrade for you: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
If you PSU has a 6-pin PEG connector for a GPU, you could get an HD7770 which would improve performance: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I'm leaning towards the HD 7770, but I'm concerned about power consumption. The PSU is only 300 watts, and the 7770 is listed at either 500w or 600w. I know manufacturers are conservative in their rankings, but even if there's an extra 6-pin connector in there, wouldn't that be too much?
m
l
June 9, 2012 6:48:47 PM
Yeah, I think I'm going to go with the 7750. Thanks!
m
l
