Please help,audio card scope hanged in middle of installation
December 8, 2012 5:35:54 AM
Hi
My problem came from my trying to add more HD which is IDE into my window vista computer,the current HD is SATA,and i carelessly inserted HD into IDE connectors without seeing that it was a masterHD so trouble came even though i threwout thatHD,the current is not operating smoothly,it hangs lot.
The audio player plays fine but midi screwed up( i use reaper )so i installed the audiocard scope again ( it's version4)and it hanged when it nearly finished.I think it screwed up the BIOS info or something like that.
I am not a technical computer guy but if i know how to correct the BIOS,i think i can cure this
thnx for your help
