G
Guest
Guest
Hey, i hust recived my new amd fx 8350, mounted on a ga 990fxa ud3 motherboard with the corsair h100 cooler.
When i run crysis 2 on max settings (hardcore, 1080p) the CPU temp goes to 55ºC but their cores stay at 40ºC all the time, anyways the cpu load when playing stays at 40 - 50%
Which temp is the real cpu temp?
i'm so confused
here some pics about it:
i'm so confused
