Using TV as second monitor and not fitting full screen
  • Tuner Cards
  • TV
  • Laptops
  • Monitors
  • Graphics
June 5, 2012 7:23:07 AM
Can any one help connecting my laptop Toshiba satellite l505 to my TV using awm cable
i already connected it but it is not filling the full screen it is just filling same size as the laptop
More about : monitor fitting full screen
June 5, 2012 7:54:15 AM
Are you trying to add the tv as a second display? If so try changing the resolution.
m
l
a b C Monitor
June 5, 2012 9:45:40 AM
What kind of awm cable are you using? Is it HDMI or VGA?
Anyway, go to display setting & set the resolution to that of your TV ( 1920x1080 if full HD or 1366x768 if HD ).
m
l
September 8, 2012 11:06:52 PM
I was having the same problem with my L750 - the following worked for me:
Control panel > display > connect to a projector > projector only.
The big black border appears if you have 'duplicate' selected (which seems to be the default setting).
I hope this helps.
m
l
February 6, 2014 10:31:05 PM
I had to go to control panel and change the battery/power setting to do nothing when the laptop lid is closed, then once the laptop has begun to boot up, clode the top and the TV becomes the only monitor. I have tried every resolution setting available and disfferent DPI (font) sizes. The besy I could do is set the resolution to 1600X900 and the DPI to 200. I am not yet pleased with the results buts its okay for now.
m
l
