Hi guys this is my first ever custom build and I need some help finding a motherboard. I want to be able to play Starcraft 2 on a least medium graphics. I also need your opinions on the build and what i could tweak to save money as i'm on a tight budget. By the way I am a computer noob.
Build:
Processor:http://www.newegg.com/Product/Product.aspx?Item=N82E16819116399
Motherboard: Any ideas?
Hard Drive:http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820576003
Power supply:http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
Disk drive:http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
Graphics card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814102988
Wireless adapter: Do I need 1? If so:http://www.newegg.com/Product/Product.aspx?Item=N82E16833315091
Total cost (after rebate) 261$
Im willing to spend 80$ more.
Opinions and advice?
Build:
