Hello guys, this is my first time posting and I hope I posted this thread in the right section. It's also my first time building a PC so I would like to ask if I'm building it right. Note that I'm on a very tight budget and this would only be used on mid-tier stuff so bear with me.
Here are the specs:
CPU: core i3-3220
GPU: HIS HD 7770 IceQ X 1gb/128bit ddr5
HDD: 500gb WDC Caviar Blue sata3
MB: Asrock H77M
casing: NZXT Source 210 Elite
ram: G.Skill RipJaws X 2x4gb ddr3-1333
optical drive: Liteon 24x Sata
PSU: ???
Any suggestions on what PSU I should buy with these specs? Recommendations to the specs? Please halp.
edit: I'm mainly playing with resolutions 1366x768 or lower, if that would help determining if my specs are overkill and is a huge waste of money.
Here are the specs:
CPU: core i3-3220
MB: Asrock H77M
PSU: ???
