HELP! Bios shows CPU running faster than designed, is this possible?
Last response: in Systems
Related ressources:
- ForumMy CPU is faster than yours! Who Cares?
- ForumGTX 280 will be faster than HD 4870/4850
- ForumAMD states K8L aka Barcelona faster than all Intel cores
- ForumCan a 2 4 Ghz CPU be faster than a 3 4 Ghz CPU ?
- ForumBarcelona 30-40% faster than predecessors...
- ForumHow you know what HD is faster than another?
- ForumIs my CPU running hotter than it should?
- ForumWho Designed This Crap? Tech Support, Need I Say More?
- ForumWho Designed This Crap? The Latest Model: Innovation or Ripoff?
- ForumMy P4 3.6 Faster Than C4Q In Running Non-Multi-Threads???
- ForumDoes the WD Raptor X HD really faster than other 7200rpm HD?
- ForumBulldozer 40% - 50% faster than Sandy Bridge?
- ForumAMD 4x4 = 15 % faster than CONROE in gaming
- ForumCan MEMTEST86+ check memory running at faster bus speed?
- ForumWill X2 939 3800+ be faster than CONROE 1.86 GHZ
- ForumCPU fan runns faster than it did before
- ForumWindows 8 faster than windows 7?
- ForumNew to building ($1,000 budget)
- Forum[Solved] ~$1200 Gaming PC Build Help
- ForumNew Build Help
- More resources
