I currently have a XFX HD radeon 6870 card. It has one fan and its pretty loud. It runs idle maybe 48C average. I want to pair it in crossfire with another card that won't add more heat to him or maybe help him some.
I tried finding aftermarket cooling stuff but they looked pretty big and one I tried didnt fit.
Anyone got good advice on the other card I should pair with this one?
Trying stay around $250 or under which should be plenty. I am not interested in selling my current card yet. Maybe if I run into more issues with heat. I mainly use the cards for gaming, I understand not all games use Xfire.
I plan to add another monitor to the mix to replace my current. Depending on the second card and the performance of the two I will buy the best monitor for the set up they provide.
My current card:
XFX HD6870 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
My PC
My current card:
XFX HD6870 1GB
My PC
1680x1050 720p monitor
HX850W PSU Corsair
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
AMD Phenom IIx6 1100T Black Edition Thubian
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103913
Fatilty 990FX professional mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157267
Azza Hurrican 2000 with every fan replaced but 4x230mm (10 Total, all other fans are 120mm. All replaced with better)
My CPU has a cooler master 212 hyper plus heatsink with 2 fans.
16GB memory 1600 channel low G. Skill ripjaws
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
HX850W PSU Corsair
