Archived from groups: rec.photo.digital (More info?)
I own a cybershot dsc-s40 and a MSX512S memory stick pro 512mb. When i
take pictures using the cameras internal hard drive, I can transfer
pictures to the computer fine. However, when I use the memorys stick
pro, the pictures are always corrupted, and when viewing them either on
the pc or the camera, I receive errors. (eg. on the pc, I can see the
thumbnail, but upon opening it in windows picture and fax viewer, it
says 'drawing failed') I have tried formatting the memory stick using
the camera but the problem persists. I can write files to the memorys
stick from the computer fine. Is this a problem with the camera or the
memory stick?
> memory stick?
Check your manual; not all cameras can use mem stick pro.
Neil
Delete delete to reply by email
