Approximate Purchase Date: e.g.: 1-3 months
Budget Range: Would like to keep it under $2000
System Usage from Most to Least Important: Gaming/internet browsing
Are you buying a monitor: Yes (possibly 3)
Do you need to buy OS: Windows 8
Preferred Website(s) for Parts: newegg
Parts Preferences: Intel CPU
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: Debating on running 1 24-27" LED monitor or doing EYEfinity on 3 22-23" monitors (depends on price)
Additional Comments:Like stated above, debating on doing 1 big monitor or 3 smaller ones... I want a nice case, with plenty of airflow, im fond of the corsair cases but when keeping the build under budget, the internals matter more than the case when $$ comes up. Also, want a I5 and the H100 cooler. Im deployed right now and will be buying this over a short time when I catch good deals, etc etc
thanks!
Overclocking: Maybe
thanks!
