GPU problem need Help
  • Nvidia
  • Cooler Master
  • Power Supplies
  • GPUs
  • Graphics
June 6, 2012 9:06:48 AM
hello im intending to buy nVidia GTX550 ti 1gb....and i have power supply cooler master extreme power 450w so will my power supply support my graphic card...plz Help...dunt wana fry my card... :p
More about : gpu problem
a b Î Nvidia
a b ) Power supply
June 6, 2012 9:27:52 AM
Does it have a 6-pin connector?
m
l
June 8, 2012 12:06:32 PM
no it have 4 pin..
m
l
a b Î Nvidia
a b ) Power supply
June 8, 2012 1:19:50 PM
4 pin is for CPU. Are you sure it doesn't have a 6/8 pin PCIe power connector?
m
l
June 10, 2012 6:29:16 PM
yup it dosent have
m
l
a b Î Nvidia
a b ) Power supply
June 10, 2012 6:34:14 PM
So yea you cannot get GTX 550 Ti as it will not work. I'd suggest getting HD 7750. It doesn't require such connecto and will work with your power supply unit.
m
l
