the quick answer is "likely" as the new GTX680 can work with a 550W provided the Amperage on the +12V rail is sufficient.
As mentioned, you generally need the specifics but considering it is a Cooler Master Extreme AND that the card is LOW/MEDIUM graphics card there should be no problems.
