Seeking Sound Advice (Pun Intended)
Hey folks,
I've recently been looking into assembling a computer. I'm a music composition major, and so high fidelity sound is very important to me, as I intend to use the computer for my work. However, I'm not very well versed in the technical specifics of the hardware, so I was wondering if any of you could fill me in so I could better understand what I should be looking for.
From what I've read, it seems that the ASUS Xonar cards are particularly good, so I've been steering towards them. I recently however came upon a particularly good deal for a machine off Craigslist, but without a soundcard. What it does have is an "MSI Big Bang XPower X58 Motherboard" whose onboard sound appears to be "Creative Quantum Wave" of which I know nothing about.
If it's useful to know, I intend to route this through my sound system, which currently includes two Polk TSi400s, and four Logitech bookshelf speakers (not sure the model), and run through a Denon AVR-1912. I eventually intend to get a subwoofer and higher-end bookshelf speakers with tweeters to fill out the upper ranges. The frequency response my sound system is currently capable of, is about 34-25KHz.
Any feedback you could provide would be welcome! Thanks!
1 answer Last reply
More about seeking sound advice intended
  1. Otherwise the XFI-Titanium HD has one of the best internal dacs outhere at like 122db or something like that SNR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829102033
    Granted this Xonar has a better SNR and better dac but for 70$ more
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829132019
    This ones also pretty good but the Xonars have issues sometimes is what I hear:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829132014
    Then if you want a totally different company I heard the HT eClaro are not that bad:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829271006&Tpk=Ht%20Omega%20eClaro
Sound Cards Computers Components Product
