Hey all.
I am currently in the process of buying parts towards my first PC build. I am going to buy the graphics card last as it is the most expensive.
I plan on getting a GTX 670 but if I cannot afford it when it comes to it, I will go with a GTX 570.
Obviously a 650W Power Supply will be enough to support either of these cards by themselves.
If I go with the GTX 670, there will probably never be any need to use SLI as my goal is to run Battlefield 3 maxed smoothly and one GTX 670 should do this easily.
However, if I cannot afford a GTX 670, I will buy a GTX 570 with plans to buy another one and SLI later on.
My questions are:
Will a 650W Power Supply be enough to support 2 GTX 570's?
Is it worth paying $200 more for a GTX 670 over a GTX 570?
If I do happen to buy a GTX 670, and do happen to ever want to buy 2 and SLI, how big of a Power Supply will I need?
I hope this post made sense, thank-you.
My questions are:
