I have a problem with a Thermaltake ToughPower XT 775Watt Power Supply, where the Center LED (PG) is green (OK) when the system is running but turns Red when trying to shut down and the system FAILS to shut down completely leaving the case fans spinning and the case power switch & HD led illuminated.
To fuly shut down the power switch on the PSU needs to be turned off.
When the PSU is turned on again (by the switch) the case fans start and the and the case power switch & HD led illuminate, but the Mobo is still off untill the case switch is pressed then the system starts normally. All 3 LEDS are illuminated when the system stops with the PG Led Red and the other 2 green, until the PSU is turned off by it's switch.
Any help and/or ideas to the cause would be appreciated
Thanks in advance
Roger
Thanks in advance
Roger
