Ok so here is my problem. I like to run 2 accounts of EVE Online with my dual screen setup and I have beenn having FPS issues. I have both accounts set to the minimum specs and it will play good but then randomly my CPU will be at a 100 percent work load and the FPS will drop. Then out of nowhere the CPU will go back to 40 percent and all will be fine. What could be the problem? Im thinking my graphics card is retro and is being over worked and putting the load on the CPU but I am unsure about how this all works. I have an 800 dollars budget to work with to upgrade my system. Can you please provide me with a possible solution and upgrade recommendations?
Win7 64bit
GA-MA790FXT-UD5P
8 gigs of RAM
GeForce 9800 GTX+
AMD Phenom II X3 720 (3 CPU) 2.8 GHz
Win7 64bit
GA-MA790FXT-UD5P
8 gigs of RAM
GeForce 9800 GTX+
