Closed Solved
Best sound card to buy?
Hey guys. I was wondering what is the best sound card I can buy? It needs to be compatible with win 7 pro.
8 answers Last reply Best Answer
More about best sound card
  1. Best answer
    i have an ASUS xonar essence and couldn't be happier ! i highly recommend it
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829132010
    also has very high reviews on Newegg. its a 5 egg product for sure.
  2. It looks nice but, it only supports windows vista/xp, not windows 7. I would have to download a rar file for the windows 7 driver :\ rather have it already supporting my os
  3. It works fine on windows 7.
  4. army1506 said:
    It looks nice but, it only supports windows vista/xp, not windows 7 pro :(
    i have windows 7, and have even tried windows 8. the card worked with both. as long as its not windows 95 ur good lol. get this card trust me!!!!
    Alright, you've convinced me to get this card lol. So I know this is a little bit off the sound card topic, but do you have any suggestions on what speakers I should get?
    sorry for the late reply!!! but i cant help you with that seeing that i dont really use speakers only a high quality gaming headset...
    i have these dell speakers with a sub.. but its nothing crazy...
    u could prob look into some logitech ones or idkkk just shop around :) good luck!
  7. Best answer selected by Army1506.
  8. Hi, I was just wondering it says its 7.1 would it be pointless getting it if your speakers are only 2.1 or 5.1? Also my headset is USB is it worth getting a headset with a jack?
Sound Cards Compatibility Components Product
