Help first build
Approximate Purchase Date: this month
Budget Range: £650 MAX
System Usage from Most to Least Important: gaming
Are you buying a monitor: No
Do you need to buy OS: no
Preferred Website(s) for Parts: amazon.co.uk
Parts Preferences: intel cpu, a good GPU
Overclocking: Maybe
SLI or Crossfire: no
Your Monitor Resolution; 1920x1080
7 answers Last reply
More about help build
  1. best to stick with one topic instead of flooding the forums.
  2. im putting it in BRITISH like you said, so please don't be a hypocrite.
  3. I'll just ignore that. You can just update the OP mate.
  4. then ill have to bump the other and flood some more :/
  5. Flooding means creating multiple topics, not bumping. Besides, bumping is against the TOS.
  6. nice to know
  7. Anyway, are you able to buy from ebuyer, aria, or anything like that?
New Build Monitors Systems
