CPU running t 90 degrees after water spillage! Please help..
Last response: in CPUs
Hello,
I just checked by CPU temp with CORE Temp programme as I felt the heat from the left side of the computer almost like a hair dryer. The temp was 88 degrees on each of the dual cores. It is a HP wth Dual cores. My wife recently spilled water on it and it cut out but after drying it, the comp is now working just very hot. Any info would be greatfully received.
