Problem with AMD Vision Control Center
So my GFX is a Radeon 6850 and its working cause i still can play WoW, but my vision control center wont open up anymore and i dont know why. PLZ Help
4 answers Last reply
More about problem vision control center
  1. Here check this thread out:
    Amd vision engine control center won't open
    http://www.tomshardware.com/forum/335236-33-vision-engine-control-center-wont-open
    If not, then update your drivers.
  2. Quote:
    http://www.tomshardware.com/forum/ [...] -wont-open
    Hi,
    I've searched assembly folder and found no files with such key, also i have all latest drivers, and issue still happens.
    I click Amd vision engine control center and it doesn't open the window.
    Any other recommendations?
  3. No one?
    Yes there is a solution to this,
    read and follow the directions carefully:
    You are not doing anything wrong, it's a compatibility bug, and it does not affect all computers...
    Sign in as administrator (If you are not administrator you may be blocked)
    Close all the applications that are being used...save and close your files...
    Turn Off the antivirus and firewall, turn off the functions of windows defender.
    If you have multiple security programs installed, they must be turned ALL off. Security will prevent your driver from installing...
    Download the latest CCC driver package, and save it to an easy location. Make sure this is the correct driver for your card.
    Delete all the current AMD video software and drivers, restart the system (the video will look screwy, don't worry)
    Now load install all the newest CCC drivers and restart the system (the driver will not work (yet) as you said, but load it anyway)
    left click start
    left click computer
    right click C drive
    Left click Open
    Right click Users
    Left click properties
    "Check" mark the box that says: Attributes: "Hidden" (there is now a check-mark in the "Hidden" box)
    Click: "Apply"
    Now the system will apply the hidden attributes...and this will take a while, or maybe a long while. Let this proceed, and don't interrupt it...
    During this procedure, a message may inform you that you do not have administrator privilege to the file you are trying to change the attributes of. That's OK. Just click: "ignore all."
    When this procedure is finished, click OK (the box will close after you click OK)
    Now you will once again be looking at folders in C drive (don’t close the C drive window or you may regret it)
    (once again) right click Users
    (once again) left click properties
    UN- check the box that says: Attributes "Hidden" (you will now take the check mark OUT, Hidden is no longer checked)
    Click Apply
    Now the computer will UN-apply the hidden attributes, and it may take a while, or a long while...but let it proceed, and finish, don't interrupt it.
    During this procedure, a message may inform you that you are not the administrator of the file that you are trying to change the attributes of. That's OK, just click: "ignore all."
    When this is completed click OK
    Now close all windows and restart the computer
    turn all the security back on.
    At this point, the CCC should be functional. Open the CCC and test the functions...
Radeon World Of Warcraft AMD Graphics
