N nonubs Honorable Jun 7, 2012 3 0 10,510 Jun 8, 2012 #1 Hey! So i´ve been wanting to buy the SAPPHIRE AMD Radeon HD 6870 1GB GDDR5 PCIE Graphics Card but I'm not quite sure if it'll fit... I've got a DH61CRBR board. Thanks in advance lads! Cheers! Will the SAPPHIRE AMD Radeon HD 6870 fit my Motherboard?
Solution dudewitbow Jun 8, 2012 as long as its pci-3 x16 it will fit on the mobo. what decides if it fits is the parts around the pci-e slot and the size of your case/wires
N NoUserBar Distinguished Nov 1, 2011 305 0 18,810 Jun 8, 2012 #2 wow I can't find any specifications for that board so I have no clue. Upvote 0 Downvote
Deemo13 Splendid Jul 18, 2011 8,087 0 31,960 Jun 8, 2012 #3 I'm thinking it will fit on the motherboard as long as it has a PCI-E on it. Upvote 0 Downvote
T tjensen_25 Honorable Jun 5, 2012 53 0 10,640 Jun 8, 2012 #4 Yes it will, your top slot is a PCIe 2.0 x16 so you can fit most modern video cards. You won't be able to use two for SLI/CFX though. Upvote 0 Downvote
teh_gerbil Honorable Apr 9, 2012 515 0 11,060 Jun 8, 2012 #5 Hi nonubs: http://www.clickeco.com.br/placa-mae-dh61crbr-skt1155-ddr3-intel-p-740.html Yip, it will fit! - 1 porta para conectar placa adicional do barramento PCI Express* 2.0 x16 I don't know portuguese, but PCIe 2.0 x16 is PCIe 2.0 x16 in ANY language. Upvote 0 Downvote
dudewitbow Dignified Apr 11, 2012 4,868 1 15,460 Jun 8, 2012 Solution #6 as long as its pci-3 x16 it will fit on the mobo. what decides if it fits is the parts around the pci-e slot and the size of your case/wires Upvote 0 Downvote Solution
N nonubs Honorable Jun 7, 2012 3 0 10,510 Jun 10, 2012 #7 Thanks a ton lads! Was really helpful! Now I'll just see if it'll work with my case n'all that jazz. Cheers and thanks again! Upvote 0 Downvote
N nonubs Honorable Jun 7, 2012 3 0 10,510 Jun 21, 2012 #8 Best answer selected by nonubs. Upvote 0 Downvote
teh_gerbil Honorable Apr 9, 2012 515 0 11,060 Jun 21, 2012 #9 Nice man, I did some digging for your specific board, you just chose the most generic answer there. Makes effort seem so worth it. Upvote 0 Downvote
