Help is this a fine PSU for my built?
Hi i really like how this site helps out, so i came back again, but sadly with another problem. Anyways i found a cheap case with psu but im not sure if its gonna be working fine with my build..reason taking this is for my budget so you guys think its fine? and work great-using it for gaming
case: LOGISYS Computer CS305BK Black Steel ATX Mid Tower Enhanced SOHO Computer Case 480W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811148046
processor: AMD fx 4100
HD: WESTERN digital caviar blue sata 6 RPM 7200 3.5
GPU: GTX 560 SE
Ram 8 GB 1600 MGHZ
MOBO: GIGABYTE GA-880GM
2 answers Last reply
More about help fine built
    GPU: GTX 560 SE
    Ram 8 GB 1600 MGHZ
    The only reviews on Newegg seems to be poor related to the power supply.
    As a general rule, the bundled power supplies are garbage. Antec sometimes bundles okay power supplies, but that's the extent.
    Get a good case, then a separate power supply, like the Corsair CX series (cheap and very good quality).
    Don't skimp on the quality (not the wattage) of your power supply. If it dies, it COULD take everything with it when designed poorly.
  2. Short answer:NO.
    Logisys is a tier 5(not recommended) psu on this list:
    http://www.eggxpert.com/forums/thread/323050.aspx
    I agree with maxx_power, Antec cases are the only ones worth buying that include a psu.
    Also, the $110 FX-4100 is not particularly recommended for a gaming pc.
    It is outperformed by the $68 Intel G630:
    Read this: http://www.tomshardware.com/reviews/gaming-fx-pentium-apu-benchmark,3120-6.html
    My rule of thumb for a gamer is to spend twice your cpu budget on the graphics card.
    In this case, your total $220 budget is 1:1.
    Split it to $68 for the cpu, and you can get a stronger $150 graphics card like a GTX560.
Homebuilt Cases Systems Product
